My Camaro was running great, then the battery was taken out for another vehicle. When I put the battery back in it wouldn't start. I have power and none of my fuses are blown, but I can't get it to turn over at all. would it be my starter?
Year & model of Camaro?
If first gen,
Do you hear a click? No click, Neutral or clutch safety switch (69 only)?
Do you have headlamps?
No headlamps, then check battery cables/clamps/post for cleanliness.
Also check buss bar at horn relay below voltage regulator and junction block next to battery for corrosion. Clean as needed.
