On the 67 Camaro converted the manual steering to power steering using the IROC steering gear. Now the steering wheel is 90 degrees off center. The steering gear is centered with the wheels straight ahead. The problem seems to be the rag joint is off 90 degrees and only installs one way. Using a new rag joint from Leepowersteering. Is there a different joint that I should be using that has the correct indexing to the steering column. Looks like not easy to re index the steering wheel because of the turn signals etc. What am I missing here? If I put the steering wheel in the correct position then the steering gear is way off center. Is there an easy fix?
