1 - 11 of 11 Posts
68 covt...
ok so i swapped out the rear studs and used ARP studs. put the rear part of the bear brake kit. finally got the wheel/tire...even got the mcgard spline drive lug nuts.
go and put the wheel on and the studs are WAYYY too long. probably about 3/4 to an inch too long. so what to do now?
i would really like to avoid the look of open lugs. are there lug nuts that are extra long?
In the 10's Moderator
Screw a nut on the threads and use a cut-off wheel and trim to length. Cut straight as you can using the nut as a backstop. Unscrew the nut and that will fix the starter thread, then lightly file the cut edge.
Should be go to go.
Should be go to go.
hmmm i would assume cutting it wouldn't have any ill effects on the studs themselves?
Banned
No problem at all IF you don't go hawg-wild w/ the angle grinder!!
If you are worried about it, then use a wet washrag to wet each one down as you cut them off so that they don't get too hot.
pdq67
Should be little heat and all at cut. You could use a saws-all too.
Banned
Well consider roundy-round, I think $1.25/each, double end BIG hex lugnuts!!
And leave the studs long!!
I think SPEEDWAY sells them if not mistaken???
pdq67
Yup... those guys have way too much money and not enough... **cough, Ill leave that alone... cough** But a local machine shop could do it for less. I mean material and time... wouldnt cost $400. I think the shop that made those knew they too much money.
I just used the McGard 60127 thru nuts with my Vintage Wheel Works V45's...
I think I spent about $100 on the complete set.
Banned
To highjack here!!
Chicane,
Did you ever check out the '69 Merc Cougar Eliminator 2-speed rearend yet here that I tried to get you to??
Here's the link to it.
http://www.camaros.net/forums/showth...-speed+rearend
I've got some money to put in on making it IF I could get the engineering blueprints off Ford!! In a New York Minute, I think it is that gooda deal!!
Let me know.
pdq67
Sorry about that guys, please carry-on..
1 - 11 of 11 Posts
