1 - 2 of 2 Posts
If you call the cam manufacturers, they will help you to pick the cam to give you the characteristics you want. Usually it's a compromise. For example, getting high RPM torque usually means it stumbles at low RPMs.
The cam grinder will want to know Rear ratio, transmission, compression, etc.
1 - 2 of 2 Posts
