:confused: I just got my car back together and the rebuilt carb seems to be making a whistling sound while setting the curb idle for final adjustment. Itv only happens within a certain range for adjustment. I can not get to idle where I want without this annoying sound. I can adjust the whistling sound by moving the idle screw (blades) back and forth.
I think the 4 holes drilled in my throttle blades for the large cam maybe causing a whistling sound when they hit a certain angle?
I have another base plate in the garage with no holes and was thinking of switching out? Just wondering if anyone has had the same problem?
Discussion Starter · #4 ·
Thanks dawg! Sounds to simple, but makes sense since I reused the older gasket. I will replace and recheck! I will keep you posted!
