Im looking into a new 383 for my 69 has anybody dealt with either white performance(not skip white) or tristar engines both have pretty good deals. Or can someone recommend another engine builder
Those look like a good value. Also look at Summit Racing, Pace Performance, and GM Performance Parts.
Before you buy, check out the cam specs on those and other 383 engines that are putting out 450 or higher hp numbers. A lot of builders use big cam profiles to get that kind of power. Those cams generally make all their power in the upper rpm range, which can greatly effect driveability.
I just finished installing a Blueprint 383 430 HP with FAST EFI from Jegs.
The quality of the engine looks great. Runs well just fine tuning the EFI. Not drive more then around the block yet.
Mark Jones AKA VortecPro may be worth a look too ;)
