I guess after all the threads I have read on the matter I am still on the fence. Help me put to rest the concerns I hear from others by providing some real world feedback.
How do they ride with the progressive spring rate (250/350?) I hear they are too soft for cornering but rise well for launching. Could a stiffer ant-swaybar help this if true?
What about using big block springs on a small block to stiffen it up a little(cut them down?)
What do you think of the shocks? Are you running the drag version (90/10?) or the street version (?/?)?
From what I hear, it would be "best practice" to reinforce the lower control arm at the mount - seems logical to me. Did you do this?
I'm pretty hard on my Camaro... hard launches, fast on rough roads, like to corner... what about you?
SoCal - Had the Qa1 kit 0n my 69 for about a year. Handled real nice around town with the small block springs, and shocks set stiff.
However, at the track, even with shocks set at loosest, the springs were too stiff, and with little front end rise, spun rear tires like mad.
Removed them, installed lightest trick springs, and kept the shocks.
Had to turn off the threads on the shock body, put a 1" extension on shock rod for travel.
Car still drives fine with shocks set firm(still no corner carver).
With shocks set loose, front end flies up on hard acceleration.
Hope this helps...................DC
Thanks don, thats just the kind of information I was after. I am currently running a stock style springs on my small block which is about 50lbs over stock (375). I've been researching the big block (350/450) progressive springs so as to get a decent firmness for cornering. I hoped the progressive nature of the spring would have risen better but it sounds like that wouldn't have been the case.
It's times like this when I truly respect the work that went into the 99 Dodge Viper GTS. Not only would the hood rise up so far as to block your view on acelleration, but it did it with independent suspension in nearly every gear, each gear was spent in about the same amount of time and it still cornered really hard to boot. Nice balance!
I too have been considering converting over to this type of setup....
I'm wondering if buying a different set of coilovers wouldn't help the situation that everyone is describing with the as shipped set. Coilover springs typically are not that expensive and there is a broad range of spring rates and heights. Coming up with a combo that is suitable for your driving style shouldn't be that much of a challenge?
Thoughts?
Thanks,
Tom
Guys,
Not to put anyones wishes down but would you tell me what is realy difrence between stock coil and schock in the middle or coil over besides wow factor and adjustability. My personel opinion, I dont see any gain. Also I realy admire and value of the opnions of David's. And as far as I remember he is thinking same way if my memory serves me right.
I don't know about anyone else but two aspects of the coil-over are appealing to me; ride height and dampening adjustments. While the landrum spring adjuster allow for ride height adjustability, it takes an hour to do so with a good chuck of effort (especially in 90 degree weather). The same goes for adjustable shocks where the landrum style springs conceal the adjustment knobs – or you have to remove the bottom of the shock, extend it and make your adjustments. It is really a convenience factor.
What I consider a setback on these coil-over setups are the shock replacements which now become costly – or have to be sent in to get rebuilt (do they cross ship?). Also, it doesn’t seem like the QA1’s are best of breed in the lines of dampening performance so the combination may be limiting unto itself.
I am already leaning toward the landrum setup as my short term solution and trying to get a decent static setting with a decent shock until there is more real world feedback across a broader range of driving with the coil-overs on a first gen.
SoCalFirstGen,
I think that what my intended purpose for these are just what you are getting at! Adjustability! I'm not that concerned about setting it up to launch really hard at the track since I'm pretty sure I'm only gonna get one shot down before that throw me out! I expect the car to run low 13's and that's gonna upset the track tech's with a convertable. What I really am looking for is a nice ride with some improved handling over the stock suspension and the ability to lower the ride heights without stiffening the suspension to do so.
Thanks for allowing to piggy back on your post
Cheers,
Tom
