Hey guys,
I was told that the leaf springs limit the width of the tire we can put on our cars. Is there anything other than a minitub kit which will allow a wider tire on our cars? Will eliminating the leaf springs allow for a wider tire? I have a 68. I do not want the tires to stick out. Also, what is the widest 17 or 18" tire that will fit on the stock setup? 275?
Thank you!!
Hey guys,
Thank you!!
Yes, a 275/45/17 or a 275/40/18 will fit if the backspacing is right on a stock setup.
I just put 275/40/18's on the back of my '67 on an 18x9 with 5.25" BS and they fit great. (leaf springs, no tub)
I did a mini-tub with my G-Bar, so I am not certain, but relocating the springs inboard should give you a bit more space depending. Just look at the location of your springs and then at your rear frame-rail, that should give you an indication of how much extra space.
If you haven't seen this thread, you might look at it, not that hard to do your own mini-tub:
The Novice's guide to mini-tubbing a 68-69 Camaro
