I know i have non staggered shocks but are they the same length?
My combo- 67 camaro, multileaf rear, 3 leaf jcw springs, multileaf cal-tracs... do I order the 68-69 multileaf shock or do I get the 67 mono shock (havent found a 67 multi shock) I did a search and came up blank..
There are no '67 multi-leaf shocks... Either shock should work but you need the matching shock plate and if the Cal-Trac's replace the shock plate you need the shock that matches their shock mount...
well I ordered shocks for a 68 multi car.. I'll let you guys know if they fit!
Shocks are the same length. The difference being that the multi shocks use a stud in the lower eye. The lower shock eye bushing is of different size. So the monos you would have to drill out to use the multi stud. Check out David Pozzi's website and check out his info.
