I did the search and found archives that said 68-72 nova disk brakes would work but nothing concrete about 74 nova disk brakes... I got everything except the booster off of a 74 nova and was wondering if that will work?
I have a 69 camaro with power drum brakes that work excellent.... I know I will need to use the master cylinder off the disk brake car because of the bore of the cyclinder and the pressure correct?
Will I need the booster off of the nova and rod off of the nova also?
I got the metering block and what appears to be a proportioning valve off the back of the master cylinder or metering block and I assume I will definitely need those?
Will I need to order an inline proportioning valve?
Anybody done this swap before?
Any help is appreciated...
Thanks in advance...
