1 - 14 of 14 Posts
Reason I ask is because I am currently running a 17x9.5 (5.5" b/s) rear on a 285/40 tire and It appears I have plently of room to go outward and I am considering having wheels made with either a 5.25" or 5.0" b/s to move them outward slightly.
Anyone running something like this...?
I wouldnt put a 315 on a 9.5in rim. I know they can fit but i personally wouldnt.
You could probably get away with a 5.25in but id make sure that when hitting bumps and turning they dont come up and rub the fender. I used a 8in rim with 4in backspacing for a while and my fender hit the tire a couple times and chewed it up pretty bad.
John a lot of what fits and what hits depends on the car. Does your car have factory or repo 1/4s? It DOES make a difference. Also what rear brakes are you using? Do they push the wheels out slightly? When you think about it a 1/4" should really not be significant. I can tell you this my '69 has factory 1/4s and there is NO WAY anything bigger than a 275 on a 9.5 with a 5.5 or 5.75 will fit without rolling lips and banging on the inner wheel well. I will most likely go with a 275 tire on a 9" wheel with 5.5" backspace to be safe. I know I could not get a 285 on my car without mods. Of course all that can change with aftermarket 1/4s but be carefull.
Thanks for the advice guys.My car still retains it's factory 1/4's and I'm not rubbing anywhere now with the 285/40's on a 9.5" wheel.The only place it did rub was on the exhaust tubing on the pass side but I had those cut off last week when I installed new Flowmaster Super 44's.
I know the 315 would require at least a 10" wheel but I've factored in the "buldge factor' as well.:yes: I got buddies here running old-school 295/50-15's...on 7" wide wheels...so I DO know about buldge.
I could just re-order my wheels (American Racing 200S) in a 5.5" b/s and be safe with a 285/40...but I'm trying to better fill the wheelwell.I can't just slap the 315/35's on this wheel because then I'll be too close inside.That's why I'm thinking about moving the wheel out a 1/4" (5.25" b/s) and seeing if the 315/35 will work on this car.It looks from my calculations that it will...everyone of these cars is different.Mine sits 23.5" from the center of the rear wheelwell to the ground so it is very low.The fronts are a shade under 23".I'm running a 255/45 on a 17x8 (4 3/4" b/s) up front and they tuck in nicely and don't rub.My koni shocks are set on kill and the car has very little body movement.
I think I'm gonna go for it.If for some reason they don't fit...I've got two other cars they probably will work on.:thumbsup:
OK...I'm now thinking of a 5.25" b/s on a 9.5" wheel...with a 315/35-17 tire.
Anyone have any experience with a combo similar to this on a '69 Camaro...?
might clear sitting still, but I really doubt it will clear moving. I did see one guy do it, but he had several inches of fenderwell clearance between the tire and fender which didn't look very good to say the least! It still would have rubbed if it came down at all.
If you're going to do it anyway make sure they'll fit something else you own, as there's no way I can see them clearing in a driving situation, even if you cut the fender lips for clearance.
Jody
Maybe you could try a 1/4" spacer behind your current wheels and see how it works before ordering the new wheels.
Discussion Starter #9
That has already been suggested and I've mocked up the wheel 1/4" outward to see my clearance and I've got the room.
Hey John - Drum or disc brakes out back? There is about 5/16-3/8" difference in the mounting pad on each side between them. My 5.5" backspaced 9.5's got real close to the fender lip after the disc retrofit...
Discussion Starter #11
Dennis,
X-77 Z/28,standard rear drums...for now.
Thanks for that bit of info Dennis,I had not considered that...and I am planning on the brake swap in the near future.Maybe i should just stay with the 5.5" b/s just to be safe.
Are your wheel lips rolled...?
Discussion Starter #13
Not rolled but trimmed slightly... I was sweating it and I only have 255/45 rubber on my wheels.
Well I pulled the trigger and just ordered the wheels and I played it safe based on what DjD said...that was probably the single best advice I've ever gotten on the internet...thanks again Dennis.:thumbsup: I had not considered the disc brake difference.What I ordered:
(2) American Racing 200S 17x9.5 (5.5" b/s)
(2) Nitto NT555 Extreme 285/40ZR17
I know this works on my car because it's what I'm currently running with VWW V-40's and Kumho Ecsta SPT's.
Excuse the neighbor's wife,she got into my picture:
I've got all kinds of clearance as you can see.
1 - 14 of 14 Posts
