Will this set up work on a 68 Camaro with disc/front, drum/rear. 17" CAMARO STAGGERED WHEELS RIMS TIRES 69-70-71-72-73
New - Staggered rims 17x8"/17x9" & 235/45/17/ 275/40/17 Item number: 330148091007
I can't know if they fit unless you know the backspacing
but from what little info you have. Yes, but the the front tires are a little taller than some people here run
Most either run a 225/40R17 or a 245/40R17 from what I have seen
anyways, these rims and tires will work but, only if the backspacing is right
Ebay Item number: 330148091007
Fronts are 17x8 with 4.5 backspacing and the rear is 17x9 with 5 inch backspace. Thanks
