Whats the easiest way to remove to window and the window crank out of a 69 camaro. I need to remove all four because I will be taking the body to get acid dipped. Any suggestions would be greatly appreciated. Thanks
The procedure is in the Fisher Body Manual. If you are taking a car apart (or putting one together) you really should have a copy.
They are available from the sites sponsor - Ground Up, see link below.
