I would be greatful for photos of the glass attached to the whindow channel, a close up if possible, and where the horizontal and vertical channels mount to the door. thanks for the help
<BLOCKQUOTE>quote:</font><HR>Originally posted by bonecrusher67conv:
The glass sits in a galvanized frame unit with a thin u-shaped buytl (spelling?) tape securing the two. This frame has integrated white nylon channel guides attached at both ends about 1"wide by 4" tall. The actual C-shaped galvanized track channel (the longer of the two) then is bolted to the bottom of the above mentioned glass frame with two small flush mount bolts. Then the scissor/regulator fits into the bolted-on C-channel. I have a door apart now and also a door assembled with the inner panel off. Let me know what pictures you need.<HR></BLOCKQUOTE>
