It is very tricky to put on. You need to put a couple layers of masking tape across the top of the fenders also. It will slide between the fender. On the end brackets you can get to the screws but it is a pain. Also depending if what king of head is on the screws limits how you tighten them. I like the socket head screws so you can use a wrench on the screw head.
