1 - 2 of 2 Posts
I checked the forums, alot of different discussions about the window washer pump remaining on all the time. I was having some trouble finding "WHY" my washers remained on. Here is what helped me,,
I removed the washer motor, behind the washer motor I noticed a star shaped mechanism that rotates when the wipers are on. This would rotate the wheel inside the washer motor housing. So .. why is my washer always running. The car had set for a long time and it was all I could do to pull the plunger out of the square box that it goes in, by pulling up on the little rod behind the wiper motor. I sprayed the entire motor, except the coil with WD 40, the plunger started popping in/out much easier. kept cleaning and working the plunger, put it back on the wiper motor and it now works properly!!! I even get some window cleaner to the windows. Maybe not a full shot, but some!! I tried priming the system but I m not sure I know how!!
Welcome gregg. And thanks for another WD40 success story!
1 - 2 of 2 Posts
