I have a 68 camaro and my drivers side window rolls up crooked the only way i can fix it is pull it by hand to straighten up how would i fix this problem.
Most likely one of the rollers is broken on the cranking arm inside the door. You will have to take the door panel off to see what exactly is wrong. If you haven't done this before I recomend you purchase a Chiltons manual for your year camaro.
