Can someone post or send me a picture of the upper dash closest to the cowl where the clips are located to hold the trim and windshield. I found a post, but the link went to hobby stage which is no longer up and running. I replaced the upper dash due to rust and have nothing to reference in order to put the clips in for a windshield and trim install. I bought a fisher manual but it is vague and gives no measurements for the clip location. Thanks.
I just put mine in, I replaced my dash also.
The easiest way I found to do this was to
1. Assemble the clips onto the trim and place them in position.
2. Install the cowl panel.
3. With everything in place, I used some tape on the windshield to mark the location of where the trim will lay against the windshield.
4. Remove the cowl panel.
5. With the cowl panel out of the way, you can now line up the trim clips and locate them to drill holes for the screws. I spaced them evenly across the front.
6. Reinstall the cowl panel.
As for the end clips my car was painted and assembled. I was able to install hex head sheet metal screws. It was a bit of a pain but definitely do-able.
Don
