1 - 2 of 2 Posts
Got my wiper motor working. :D Now my issue is the wiper switch. :mad: The motor only works when I hold the wiper switch in. I've read on some posts that the two little grounding tabs in the back of the switch are normally the issue. My questions: a) is this my problem b) if it is, what are those tabs supposed to ground to? Any advice would be appreciated. Thanks. Mark
welcome to Team Camaro Mark, you only need to post your question in one section, the Elec. one is the right one for your problem with the switch.
Posting multiple times will spread out answers and later searches wont find it. Im sure you will get your problem solved in the Elec. section.
1 - 2 of 2 Posts
