1 - 2 of 2 Posts
I try my best to avoid the rain where I won't have to use my wipers, but this past Saturday I got caught out in the rain coming home from a car show and found out that the wipers don't work. The last time I know they were working was about a year ago when I was caught in a rain going to another show. The fuse looked good, but I changed it anyway but it didn't help. I couldn't read the fuse size real good, so could someone tell me what size it takes where I can be sure I put the correct size in? What else can I look for to find the problem? Any help I can get would be appreciated.
Donnie...
Sometimes the clips holding the fuse will corrode ... Make sure they are clean and that you have good contact...Also, is the switch working properly?...Use a multi-meter to check voltage at the motor itself and the ground ... If you have volts and ground, make sure wipers are not somehow binding ... Lastly, you may have bad wiper motor
1 - 2 of 2 Posts
