Did you fill in the holes, as they should be on the firewall. Also note that the after market ones may be wider than the stock one. Not sure on all brands, but if it is too wide it will look off in my opinion. Also you can get correct bolts if you want the stock look. They should be 1/4 heads from what I recall. I just got a new one as well.That is correct, I already have a new one, I just needed to see where it is screwed to and location. Thanks, Jerod
