I know this has been hashed a few times, but....
First, please don't tell me to buy a complete harness. I just want to get mine looking and functioning as new.
The wrap is easy. But, I cannot find a source for exact matches of the "routing clips", i.e. those little black or brown (mine has some of both) push in clips that are attached to the harness via the tap, along with each clip being stapled to a longer piece of plastic for stability.
Surely someone has a source. There are two main types. Straight and offset. There is an offset one in the tail lamp harness and another one in the engine harness between the two horn wires. I would be happy with either brown or black.
Already tried auveco. They have a gray one that is close on the straight clips, but would like a brown or black one.
Rick's sells an offset one for $3.99 each. The ones I have found from suppliers are normally 25 to a box for around 12 bucks. Just haven't found the supplier that makes the ones that Rick's sells.
Apparently the clips we need are identical to the ones used in 60's Fords, except the ford version is opaque white. This guy says a black reproduction is available, but I can't find it:
http://www.deadnutson.com/catalog/item/4065497/3873071.htm
