I have a 5 Speed, 6 Cylinder Camaro that will not start at all. Originally it came with some problems I could handle; every time I tried taking it off first gear it would jerk a lot (like it didn't want to move forward). and it would turn off constantly leaving me on the side of the road, and in order for it to start again I would have to move around some wires behind the ignition wires on top of the engine. I was told I could fix the jerking by changing the ignition wires, so I did, and I made sure to pull them out and replacing them 1 by 1 and I also made sure that they clicked in correctly (even the ones at the bottom of the engine which was almost an impossible task to do). I even got a new battery in it. but when I try and turn it on, all I hear is a thump like sound. It looks like its goanna turn on because all the sensors begin to move and the dashboard light up, but all I hear is the thump sound. One last thing I think you should know, before I began to change the ignition wires, I tried turning on the car with the new battery, and I heard the same thump and smoke began to come out from the section behind the ignition wires.
Any help would be greatly appreciated.
