Just ordered a color wiring diagram for my 67; the headlights are not working; may be that both headlight low beams are burned out, so that will be the first thing I probe voltage for (at the connector for the headlight bulbs).
Also notice that when I pull the headlight switch to the first position (parking/dash lights), the gas gauge needle drops to the "E" mark; push it back in, and the gas gauge works normally again. Knowing that the sender in the gas tank is a variable resistor sending a ground, this tells me that the light switch is somehow supplying a ground to the cluster gas gauge. Maybe the cluster circuit "film" is bad. In searching this forum, I found the descriptions for the copper runs on the cluster film, so I'll look for ground shorting the gas gauge.
The fun begins.
The fun begins.
