i installed a 78 305 with an automatic 350 transmission into my v6 5 speed camaro. it started and ran great for two days. then it would not start. when i turn the key there is nothing. no click, nothing. i would have thought it was the clutch wire that tells the car not to start unless the pedal is pressed down, but i took care of that and it started for two days. i replaced the starter, the starter celenoid, and the ignition. any ideas what else it could be?
Some cars had an interlock that prevented starting unless the trans was in reverse, or clutch was depressed. Maybe your car had that.
David
The older I get, the faster I was!
