i WOULD LIKE TO INSTALL THE FACTORY CONSOLE GAUGES IN MY 69 CAMARO I BOUGHT USED, BUT I DON'T HAVE A WIRING DIAGRAM FOR CONVERTING FROM THE OLD IDIOT LIGHTS TO THE GAUGES. PLEASE HELP. LEE
I bought a used set of guages from Camaro specialty in New york. (near buffalo I think)they had all the harnesses to do it. You'll need a new harness for you console cause there is no provision in a console wothout guages. The instructions were very good. It was Factory fit brand harnesses. But you'll have the fuse block apart adding and deleting wires. Some go up to the horn relay for power. All the wires were the right color and length. And buy a water temp sending unit from them if you use them. I tried others and did'nt get the correct indication on the guage. But it was pretty much a plug and play deal.
Black 69 camaro
[This message has been edited by HOTROD69CAMARO (edited 08-16-2002).]
I made my own harness, it's not difficult. I believe I made a copy of the diagram. I could fax it to you.
The only sender I could find that worked correctly with the factory temp gauge was made by standard, the part # is TS6
68 z28 ,68 rs 327 ,73 454 vette, 2 goofy kids
[This message has been edited by dale68z (edited 08-17-2002).]
