I have 1986 Z-28 and have recently changed the fuel pump in the tank. Upon completion
I had no power to the pump so I ran a 12 volt
switched source from the accesory panel to
the pump and it worked but the engine would not run. I have since removed the TPI completely, installed a performer intake a
holley carburetor and a brand new distributor.(no more computer)It runs fine, but when I turn the key off to shut the engine down it takes a few seconds for the ignition system to shut down and actually kill the engine. Has anyone experienced this type of problem?
Discussion Starter #2
For some reason the electric fan was backfeeding to the ignition somehow. I relocated the power source to the accessory
panel and the engine shuts down as soon as I
turn the key off.
When you kill the ignition, the fan is still spinning. It then acts like a mini generator for a bit, feeding enough power back to keep the motor running. Been there done that!
Mark
1992 Firebird 355/Six Speed
1991 RS 350 / 700-R4
