I say yes providing the wheels have a 4.5" backspacing.5-120-65mm = 5-4.74 inch and thats the right bolt pattern.
the guy at discount said they had a zero b/s so not sure what that means. thanks for the help so far
i was just told that it should be 4.5 b/s so would that work with the tires i want
245-45-17
275-40 or 45-17
I think the 0 offset means the mounting face of the rim is in the center of the wheel width. So if they're 17x8 then it would have about 4" of backspacing. You should double check to make sure what I'm saying is correct, but that's how I understood it.
ok i see what you mean. then 17x8 would be real close for the front hmmm 4 b/s maybe a 225-45-17 tire any of you wheel experts think this would work?
