1 - 14 of 14 Posts
1969 Camaro ss, 396 big block, 4 speed munice
hello, anybody know where I can get a decent LS2 engine with the T56 manual trans? Ive looked online but prices seem expensive and most of the engines have high mileage. This engine will be for a 1969 camaro. Thanks.
Any reason for LS2 vs LS3? Probably many more LS3’s out there as they were used in Gen 5 cars.
Discussion Starter · #3 ·
well due to the fact that they are cheaper if im correct. i was looking at the LS3s but they are expensive atleast for me. i already paid an arm and a leg for my camaro. i figure why not an ls2. any suggestions...
Discussion Starter · #5 ·
What’s wrong with your 396 ?
Do you have a real 396 car ?
Same ?’s for Muncie change ?
Nothing is wrong with the 396. it is real 396 as well. Does have a 4 speed muncie. i just want to go with a modern engine where i can have between 400 to 500 with a couple upgrades. Also reliable and better fuel mileage.
The 396 is easy 400 plus HP.
Many consider Muncie smoothest shifting trans ever.
If you have a real 396 car, I Hope you’ll save the 396 should you ever want to sell car.
Discussion Starter · #7 ·
Oh ok great to know. I didnt even know about the engine or Muncie being the smoothest. In this case ill keep both just in case i do sell the car in the future. But any suggestions where i can get a decent LS2 maybe an LS3 at a reasonable price?
Reasonable barely exist currently, all the wrecks are selling high, and in turn parts as well. Friend recently had ls3/tr6060 sold for $6800
The days of getting anything LS for not a lot of money are over, especially now that the supply chain is down on the new engines.
Here's a Ebay low mileage ad, auto but maybe you could recoup some money from the trans and buy a TKX. Anyway you look at it you're gonna be 10K in at least and you're taking a chance with a used engine. Plus it might need a cam swap to achieve more HP.
Look for an LQ9 or LQ4. Good platforms to build on way less than LS. Iron block but if on a budget the extra 100 or so lbs doesn’t mean much.
10k miles on a 2014 police pursuit vehicle. I’m a little skeptical… ;)
Don
Don
Don, maybe you're right. Of course if you're gonna dish out that kind of dough you would need to check things out.
I myself wouldn't buy a used engine unless I knew where it or who its coming from, hence why I decided to build a iron LS3 with better parts than a factory LS3 for about 7k CA.
Car Motor vehicle Automotive design Automotive air manifold Vehicle
Rad, headers, homemade cold air intake extra.
Discussion Starter · #13 ·
Well at almost 6k without the trans i might as well get an LS3 that has everything included. Im seeing prices between 7k and up depending on the mileage.
Hector, your choice, build and money. Keep in mind that once you get the engine and transmission you then need to get a fuel system, trans mount, clutch actuation, exhaust, some electrical wiring, etc..... If you're at all knowledgeable and mechanically inclined then you can save a few bucks by doing some things yourself otherwise you're gonna have to pay.
Here's a guy in Cali that could possibly be of interest.
Whatever you choose good luck.
1 - 14 of 14 Posts
