1 - 2 of 2 Posts
I've had my '67 conv for a year now and it's much improved thanks to this site. Here is a list of a few things that I've done. Some of this may be simple to many of you but it's all a first for me....Thanks
-Replaced the 8.2 rear with an 8.5 posi(I found it on this site),put in a new torque converter,new pump and a shift kit in the TH350,put multileaf springs on the rear, new front suspension bushings, subframe connectors,new ceramic coated headers, upgraded distributer, MSD ignition, recurved distributer, fixed vacuum secondaries on card, fixed "hot" starting problem, solved timing problem.....Plus all the little things..fixed horn, window cranks, speedo gear, many wiring problems, and many more....Again, Thanks to this site and everyone that contributed...
Sounds like you got a lot done in year.
I agree, this site is great. Someone always seem to have the right answer to every problem.
Kel
North Texas Camaro Club
Is the glass half empty or half full???.....Neither, the glass is twice as large as it needs to be!
1 - 2 of 2 Posts
