i have a question what exactly does this yellow wire from the starter do? if i hook it up my car wont run, with it off it does what do you think the problem is? thanks oh i put an aftermarket tilton mini starter in, should this make any difference? thanks
With the mini starter you don't use yellow wire just purple wire, I had same problem once. I don't know the technical reason for this just know that's what you need to do.How's everything in Troy? Used to work const down there years ago,gas pipeline jobs.Remember a tavern there that had great sandwiches can't recall the name.I live in Oswego RACERMIKE-68 RS Z/28 #s match heavily modified. GOOD LUCK!
