I have searching through the threads here and P-T as well as Pozziracing for about a week straight and I know there are tons of opinions on the proper modification/UCA/Coil setup, but I have not figured it out yet.
From what I have learned, I need to do the G-Mod and upgrade to some Hotchis UCA (or similar) to fix the geometry up front...Got It.
Now, assuming the G-Mod and UCA have been upgraded here is my confusion.......I have a buddy (I know how that sounds, but bear with me) who's been around the industry a bit, but doesn't know 1st gen Camaros like some of you. He recommends the drop spindles vice drop springs and this is why.....
The natural movement of between compression and decompression of the front suspension causes the wheels to move between negative and positive camber being the worst when compressed. He says that drop springs would keep the vehicle at a worse camber at all times due to the pulling action of the steering components. Whereas, drop spindles would maintain the proper geometry. The caveat is that larger wheels would probably be required to avoid the contact between tie rod and tire.
I didn't want to go larger than 17" or 18" wheels, so I am wondering what your take is on the opinion above. Do drop spings counter the benefits of the G-Mod and upgraded UCA's? Most people are running drop springs, so I didn't think so.
Also, anyone running the Hotchis 3" drop springs? Any issues with tire clearance?
