I have searched on this site and done extensive research in this subject. Now I need help. My 68 gauge reads at about the 3 o'clock position (125% full). I made a new ground for the one under the tank (although the old one looked good) and it did not help. So I then took the wiring harnesss loose at the junction right before it goes into the trunk floor. I put a test light on the harness, with the key on, and got a light AND the gauge moved toward full. My question now is this-- Does this automatically mean that the tank has to be pulled to check the ground attachment at the sending unit itself? Or can the problem be a ground to the gauge itself? If that is the problem, what specifically do I look/test for?
Thanks for any input.
Brad
68, 327, TH350 (assembly in process)
Godspeed #3
Brad
Godspeed #3
