21 - 30 of 30 Posts
Cortez Silver with standard blue interior. That is a sweet color combo, I had one with that same setup last year, very clean looking.
Ill post them here, and let you guys sort them out.
1) 69 DZ mot, V1001DZ 19N516833, cast date I 24 8 cast number 3932386
2) 69 DZ mot, V0509DZ 19N647209 cast date D 27 9 cast number 3970010
3) 68 MO mot, V0524MO 18N456650- This one looks like it was stamped twice, over each other. This number may be wrong, Ill check it again, and have someone else check it. anyways, cast date E 17 8 cast number 3914678. This is a two bolt main, with the 5 windage tray main caps.
4) 68 MO mot, V0403MO 18N414624, cast date C 28 8 cast number 3914678. This also has the windage tray bolts, with two bolt mains.
The other two engines may go to two of the cars I have here, If not, Ill list them also.
Hello this is nothing short of an emergency I need you to call me immediately at 303-919-6450 you have the motor v1001 DZ that I need to get from you that will go in my car produce that day thank you so much I appreciate it if you contact me at crazydogranch @gmail.com
Geesh, he either blew coffee all over his monitor or pissed his pants when he saw that vin and how badly it's wanted/needed....one could only hope the right person might see this.
Price just went up $10Gs too lol
Reactions: Gene Roybal
Question is
Does he just need that date? Or does he actually have 124379N516833?
From what he typed, I take it as he needs that date as his car was built that day,
Reactions: HawkX66
Question is
hello the 19N5163833 does not matter looking for V1001DZ day of production with date code cast on block from late 1968 October 1st THANKS!!!
Gene
I have a V1002DZ here in WA state. Dated waterpump and carb with Sep dates that lines up with it as well. 186 heads from July and Sept. Original bore, crank and cam. No pistons or rods. Close...??
update I spoke to Tenzs and he sold all the the motors to someone in Tennessee, if anybody knows who this individual is it would be great to forward this information thank you all for your efforts
Gene
21 - 30 of 30 Posts
