What's the trick to getting the Z bar off? I disconnected it from the bracket on the subframe (and removed the bracket) and pilled the pin from the rod that connects to the pedal and there's nowhere for the Z bar to slide off or whatever its supposed to do since the inner fender is in the way and it doesn't look like I can remove the bolts from the bracket on the engine unless the engine is out. Am I supposed to take the inner fender off?
