I am using a 4 quart oil pan on a ZZ502 to fit it in a 68 and want to make up for the lost oil volume by using an oil cooler, preferable one with the GM lines. Has anyone used this set-up?
Ive not used an oil cooler and I dont have that big power plant, but to cool it down also use synthetic oil, Amsoil or mobile, that will cool ya down quite a bit.
click
69RS 350/255 LM1,TH350,Dover White,Blue Vinyl top
F&R spoilers,pdb,Close ratio ps,am/fm,3.08 Posi.,A/C,
fold down rear seat.
My RS www.brainerd.net/~knudsen/69RS
GM can't make an oil cooler line that won't start leaking after a few thousand miles. you could use a factory cooler and make up some custom hardlines with aftermarket braided flexible lines or something. the cooler in my 94 cop car Caprice is pretty big, but the lines leak a bit where the flexible line meets the hardline off the engine block.
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels. 12" Corvette brakes on the way.
see pics here http://community.webshots.com/user/novaderrik
