I will try and post ap icture of the tag i am looking at, if anyone can help me decode or point me in the proper direction
so assuming this is accurate, there were no plain old black camaros built after january? wierdScott, your tag is a reproduction. The A-A (Black) exterior was discontinued at the end of 1967, so any car that was painted black after that would have used a --- for the paint code since it would now be a special order. You can read more HERE.
Ed
No, black was still available, but only as a "special order". And like I said above, the Trim Tag code would have been marked --- instead of A-A.so assuming this is accurate, there were no plain old black camaros built after january?
You can do some detective work (there are several indications), but without documentation, there's really no way to verify an SS in 1968 unless you have someone like Jerry MacNeish come out and inspect it. He can go over the car and tell you if it left the factory as an SS.any way to determine if a car is a real SS or big block, without paperwork?
well considering its track use and nothing original in the drivetrain, there are few things to go on. Ed, what would you say about the red line on this tach?Scott, HERE'S a good place to start your research. It doesn't go over everything, but it does go over the basics.
And to add one other point, even documentation is suspect nowadays since a lot of it is being reproduced. And a few people can even "age" the fake paperwork to make it appear genuine! Luckily, even the fake "genuine" paperwork has flaws and can be exposed by experts like Jerry and Kurt, etc... We have a TON of REAL paperwork examples in the database and can tell fairly quickly when the documentation if fake.
Ed
I have been staring at this trim tag for quite a while now and comparing it to photos of other 1968 Los Angeles tags from the same month and the same week.
I understand that the "A-A" color code is a big red flag for that tag, but everything else about it looks totally legitimate to my eyes. Is it possible that the "A" color code was stamped on a few trim tags around this date instead of the typical "---" code?
-Jeff
Hard to make a definitive call on this one, but I think it's real.
