My 1967 Glove box has the following Label:
PART NO. 3917572 (the part number is on all the labels at the bottom)
If you can not read the part number give me the numbers as follows:
Cool HOT
xx xx
xx xx
xx xx
xx xx
VEHICLE LOAD LIMIT = xxx LBS.
This does not appear to be a common label and I am trying to find out why. I have a friend with this label also.
If you have an ORIGINAL 1967 Camaro and you have this label, please post the following. It won't help at all if you do not have the ORIGINAL information on the car.
Engines Size & HP (If you don't know HP and just motor size, just put that)
Engine I.D. if you have
Transmission Which Auto or Which Manual
Rear End:
Convertible: Yes or No
What Interior: Standard or Deluxe/Custom
Original Tire Size:
Plant: Norwood or LA
What you don't know, don't worry about. I will give the results.
If you have a car that you do not want to post here, send me a private mail and I will use the stats only.
Cool HOT
xx xx
xx xx
xx xx
xx xx
Rear End:
Original Tire Size:
