1 - 15 of 15 Posts
johnny67
Just wondering how much of difference will a 7 blade OE clutch fan make from a 5 blade OE clutch fan. I'm trying to stay with a stock appearance.
I have a high flow pump new clutch and new 4 core rad and a high flow thermostat. The only time I get too hot is in really bad traffic and 90' plus weather. thanks
Since you have a new clutch I would recommend the 7 blade for the bad traffic situation. The 7 blade will really pull a lot of extra air Thur the rad. at low engine speed. If you get a 7 blade make sure to get it for the clutch you have now. THERE ARE TWO DIFFERENT SIZES.
Bob C
Thanks Bob,
I just got one on ebay that is for the 68 camaro # 3931002 7 blade. I will give it a go as my last option to stay with a stock appearing engine.
I have the 7 blade fan in only problem is it lines up worse than the 5 blade did in the shroud, it's too far to the drivers side and an inch out of the shroud. My guess is to take a close look at my engine and frame mounts and see if they are correct. But the main thing is if it keeps cool, and so far so good.
[URL="
[/URL]
Discussion starter · #6 · (Edited)
thanks Bob, no AC. I just wanted to go with L78 pulleys all around a little more expensive but they should last a lifetime.
The engine is offset by one inch to the passenger side though because the drivers side mount is taller. I read that there were not any small block frame mounts that did this?
Either I have 67/68 BB frame mounts or 69BB mounts. I have to check. What's the easiest way to tell?
Once I figure that out I have to see what engine mounts are there. Does it look like the 69 interlocking one?
[URL="
[/URL]
Discussion starter · #8 · (Edited)
Bob, thanks for the help, it is hard to measure but I think it is 1 3/4" on the drivers side frame to bolt hole.
The passenger side is 1 3/4" also.
Johnny,
I have a pair of frame mounts and they measure 2" so your measurements are close. If you have SB mounts then this could be your problem.
Does anyone have a drivers side BB 67,68 frame mount they can measure from the frame to the center of the bolt hole?
Bob C
Discussion starter · #10 ·
Bob, I think I am going to order a new set of the proper frame brackets and motor mounts for a 67 BB 396. It should only be about $150 but thats with all new bolts also. Then I can put this mystery to rest and hopefully it will put the engine in the right spot.
When I get the ones out that I have in the camaro I will post up what they are. My guess now is 69BB interlocking motor mounts. The frame brackets at 1 3/4" matches the left hand side of a 69BB bracket but the pass side I can't find a match at that height. The right hand side of a 69BB frame mount is 1 3/8".
Johnny, for 69 BBC the drivers side bolthead is against a sleeve (oh man, the proper name has gone poof in my mind) that holds the bolt in position so as to pass through the interlocking engine-side bracket. It's shown on page 745 of Classic Camaros 2006 catalog. Exactly like my original.
Discussion starter · #12 ·
Fred, I'm not sure of what you mean. Are you saying that the mount I have in the pic does not look like the 69BB one.
:yes: And Just checked CI online for a picture. Nothing. Only the part description.
Discussion starter · #14 ·
Fred I am going to just get new ones but is there anything to be worried about when it comes to the stock mounts for 67/68. I read about the recall back in the 70's.
Na, they're all interlocking now. Aren't they? Who would make such a thing?
1 - 15 of 15 Posts
