Here is my problem, the local track (1/8) mile is overrun with mustangs.I finally go to run and have a lousy 9.0 run! The car is a 69 SS with a 427, 350 auto,(1400 stall),12 bolt with 3:55 gears. Solid body mounts, subframe connectors, ssm lift bars, with 255x60 TA's.The motor: 750 holley vac. sec.,performer intake,headers, duals to the rear, heads and intake ported, the heads have 454 valves, the sig erson cam has 228 @ .050" , 470 lift and I believe 288 total duration. Hei ignition with a aftermarket coil, the rest of the motor is factory parts. My times are: 2.2 60 ft 9.0 ET @ 81.5 mph.Is this the best I can hope for with this?
