are they xenon ones? you know, like the blueish whiteish colored headlights that newer cars have, and where would the cheapest place be to buy them?
I can understand what you're saying, but anyone who simply throws in a set of lights without checking the aiming is crazy. I have NEVER had anyone flash me to tell me my lights are blinding them.those lights piss me off. unless you are in a jacked up SUV, they make you go damn near blind when you encounter a car with those lights. they might give the driver of the car they are installed on a sense of security, but they make every other driver on the road temporarily blind.
The reason your lights are the way they are is because they are factory and they are auto-leveling. The next time you turn them on, watch if you are off level a bit. You will see the light actually bounce a bit as it finds level. It's actually pretty cool to watch.My wife's STS has them, and I like them on that car. They are automatically "hooded" for a sharp cutoff above a certain height unless high beams are on.
I think that one of the biggest problems with them is they are frequently not adjusted correctly, combined with the ever-present idiot who won't dim his lights for some reason.
Jim
The lights you are referring to are no where near the light output of a true HID. The reason manufacturers throw that crap on there(5000K), which by the way is 100% false advertisement, is so people will waste their money. They do this KNOWING, once you install an electrical item, IT CANNOT BE RETURNED!!! I think it's a horrible way for a company to make money. EVERYTIME I had a customer come in and wanted to buy those crappy things, I would tell them to steer clear. DO NOT WASTE YOUR MONEY!!!!!!!5000k halogen will be the cheapest way, such a piaa, not necessarily have to convert to an HID kit, itll give you the a whitish look, but nothing compare to for example a bmws.
the aim doesn't matter- they are just flat out too bright.I can understand what you're saying, but anyone who simply throws in a set of lights without checking the aiming is crazy. I have NEVER had anyone flash me to tell me my lights are blinding them.
do as I do I throw on the brights until they passAMEN! tired of those lights come at ya and cannot see anything ahead for a few secs...
more danger to oncoming cars...
sometimes it just makes them turn on their bright lights, which is even worse than the low beams- about like staring at the sun.do as I do I throw on the brights until they pass
pisses them off hehe.
Unfortunately, your high beams are not as bright as HID's and the high beam gets soaked up by the HID's so it doesn't quite work as you think.do as I do I throw on the brights until they pass
I have had 1000's of cars come at me with HID's and I don't think they are any worse than any other light that is aimed properly. If they were, then the factories WOULD NOT be able to make them. ANY light is going to be bright if it's aimed at your face. Take a standard 55w low beam and aim it so it's facing oncoming traffic. Have someone drive said car at you and then say it has nothing to do with the aiming of the light. It has everything to do with aiming. The reason OEM hid's are auto-leveling is so they won't shine in the faces of oncoming traffic. Aftermarket hid's are not so EXTRA care must be taken to aim them properly.the aim doesn't matter- they are just flat out too bright.
the reason no on ever flashes their high beams at you is because the people you encounter are trying to look away from the blinding beam without swerving into either you or the shoulder or closing their eyes.
have someone else drive you car while you drive another car in an opposite direction just to see how others see you. then have them follow you so you can deal with the blinding light reflected at you from your mirrors. you can dim the rearview mirror on the windshield, but the mirrors out on the doors are still aimed right at your eyeballs.
those lights are no better than the idiots that think that they need aftermarket off road driving lights under their bumpers, and i think the DOT only allows them because they come standard on expensive high end cars.
