Why do yopu think it needs rebuilding...
The basics are simple as Smitz mentions above
(pins, bushings, and weights).
Weights dont tend to wear
pins can wear even if bushes have been word for a few decades, and even so a new set of bushes will fix and last a few yrs.
If the pins are warn there will most likelt be wear in the main shaft and bushes...And it is the shaft that normally wears....the shaft pins etc all come as a single part...
Do not touch the main shaft bushes un less you REALY know what you are doing...they are sintered...check out a couple old threads on that subject.
A worn shft/bushes shows up with a timing light at constant rpms with the timeing wandering around +/- a few degrees...and you will feel the play/slop inside.
The VA simple check, suck on it real hard and see if it holds the vac.
A full check is a small vac pump...those ones ppl blead brakes also fo this...they have a vac gauge on it
put your finger on the actuating shaft and note the amount of vac needed to start moving the shaft and the amount needed when it stops moving...compare with the specs for that part #
If both of the above is ok you can assume 95+% the amount of degrees will be right.
If u want to check that, hold the engine rpms at consatant speed...say 1200
Pull a vac with the pump..the crank degrees will increase..and so will the rpms...keep rpms constant...and pull full vac..note the crank degrees at the start and crank degrees at the end
Be carefull when comparing to part # specs....they could be in cam degrees...these are 1/2 crank degrees.
