There has to be a better way to attatch this line to the rear end housing.Any suggestions other than zip ties?
What bracket is that?Don't forget you need a bracket, where the line goes to hose, and enough hose for the
calipers to move and be removed.
Think of the brackets for your front end. Mounted to the sub frame,What bracket is that?
Scott...Awesome than you! Will order those now
UPDATE:Well Outta luck they wont ship anything less than $25!!!
Kev i have that piece that attatches to the cover bolt!Scott...
I have a 12 bolt out of the car so I can make you templates of the tabs and the bracket to hold the brass splitter union to the cover bolt along with the measurements. Give me a few days...ok.
Kev
Black paint. :thumbsup:What color is the rear end housing suppose to be BTW?
