hey guys, my powdercoater sandblasted everything on my rear housing. this includes the carrier bearing race seats. is that going to cause me any problems?? other than that it looks brand new
thanks
Steven
thanks
Steven
yepDid he do the same to the pinion race seats?
I'd check his prostate with it. Seriously, though, I hope it's OK.#%@#!! what can i do if it IS ruined??
Like Freddie said in his reply - I also leave the old races and caps in place when sending a housing out to prevent just this kind of stuff.my old races werent in there. ...
and SCRUB brushes, several times. Then do it again.Since the inside was blasted....fluse it real good with brake kleen (about 4-6 cans) and be sure ALL the abrasive is out :yes:
You want and NEED all the abrasives out of the inside :yes:i have just powerwashed it and used scrub brushes and brake clean. then powerwashed it again. before i had it coated, i used a wire wheel arount the axle tube/housing and ran a weld bead all around so it is super strong now
thanks
Steven
