This thread is a few months old but addresses my problem... sorta.
Keep in mind the wheels/tires are mounted on the car so my measurements aren't easy to make.
My 69 came with the MB Old School wheels and Kumho Ecsta ASX tires which are a pretty good Z rated tire.
Fronts:
17x8 (haven't measured but I'm sure that's what they are)
245/45/17
Rear:
18x9, now Discount Tire only shows an 18x8 with a 5x4.75 bolt pattern but my measurement shows about 9" wide, tire is about 11" wide so the wheel might even be a 9.5.
Here's the problem. I get a bit of rub, yes the rear suspension or at least the crappy air shocks need to go... but here's the problem, the rear is a 12 bolt out of a 70 model Camaro which if I understand correctly is about 1" wider. So figure 1/2" per side too wide.
Second problem: Discount Tire doesn't show backspacing but does show offset on a page I found.
http://www.discounttiredirect.com/direct/wheels/mb_wheels/product/byName.do?tmn=Old School
So, the fronts never rub, I'm happy there but the rears are obviously off and quite frankly I'd be happier with a 17" wheel and more sidewall.
The 18x8 they list with a 5x4.75 BP has a 0 offset.
The 17x9.5 has an offset of 6 and the 17x8 has options for an offset of 0 or 6.
So, let's assume that my measurement is off some on the 18 width, say it's an 8" as listed on their site and has no offset. I'll gain a 6mm offset with the 17x9.5 and I've read on a few forums that this wheel has a 5.5" BS. I've seen numbers of 4.5 and 4.75 BS for the 18x8.
Assuming I'm starting 1/2" wider on each side because of the 70 model 12 bolt then I'm already at that disadvantage. Would the 17x9.5 with a 5.5"BS and a 6mm offset buy me any more clearance?
Found this on the Chevelle website:
How to Measure Wheel BackSpace:
Items required to measure wheel backspace:
Tape measure
Straight edge
Wheel w/o tire (preferred)
The easiest way to measure backspace is to lay the wheel face down onto the ground so the backside of the wheel is facing up. Take a straight edge and lay it diagonally across the inboard flange of the wheel. Take a tape measure and measure the distance from where the straight edge contacts the inboard flange to the hub mounting pad of the wheel. This measurement is backspace. The above photo shows three wheels with 2",3", & 4" backspace.
Off Set: Measuring Wheel Offset
To calculate offset you'll need the following measurements:
Wheel backspace
Wheel Width
Wheel Center line (outboard flange to inboard flange measurement / 2)
Subtract:
Wheel center line from Wheel backspace to get offset. If backspace is less than the wheel centerline the offset is negative
If backspace is greater than the wheel centerline the offset is positive
Tip:
To convert from inches to mm multiply by 25.4
To convert from mm to inches divide by 25.4
Backspace to Offset Conversion Chart
The table on the below is a quick reference for finding offset, pick the rim width and follow the row over to the backspace of your wheel.
If you look at the chart above then the offset of 5.5" agrees with the offset of 6mm.
So... using the chart above on my 18x8 having a 0 offset then it should have a 4.5" backspace and I should gain about 1" per side inset/backspacing going with a 17x9.5 and 5.5" BS... if my math is correct. But then add in a 1.5" wider wheel and I'm actually adding .5" to what I have now?
UPDATE: Called Discount Tire direct:
17x8 with a 6mm offset has a 4.75" BS
17x9.5 with a 6mm offset has a 5.50" BS
18x8 with a 0mm offset has a 4.50" BS
What I think I need is:
17x9.5 with a 6-6.5" BS or more likely... a 17x8 with a 5.50" BS.
I'm also going to check the numbers on this rear end to verify what it is.
Someone check me on this.
