I'm planning to pull the engine and trans out of my 69 to do a tranny swap to a 700r4 and while I've got the engine out I want to do an upgrade to gain some HP and Torque. The engine is a GM crate 350 HO with 330 HP / 380 FT/lbs torque with FAST EZ EFI and the following specs:
Camshaft duration (@.050 in): 212 degree intake / 222 degree exhaust
Camshaft lift (in):.435 intake / .460 exhaust
Hydraulic flat tappet
Compression ratio: 9.1:1
Cylinder head Type: Vortec iron; 64 cc chambers
Valve size (in): 1.94 intake / 1.50 exhaust
I don't want to touch the bottom end, but I'd like to try to get into the 400+ HP range with just valve train changes - simpler is better. I don't want a beast... it needs to be good to drive daily (not a big lumpy idle and decent fuel mileage). I'm also in the Denver area, so I loose some power up here.
The questions I have are:
1) Will a head upgrade to aluminum with bigger valves / better flow #'s make a big difference on their own (without a cam change too)? Or, should I stick with the iron Vortec's?
2) do I need to do a cam upgrade with heads or can I just do heads and get what I'm looking for? If so, should I do a roller cam with roller rockers? Can I just do roller rockers without a cam change if I do just the heads?
3) I'm comfortable doing a head change, but have not done a cam install before, is it straightforward (timeing set, degreeing, etc)?
4) Of the big name head / valve train makers - which ones make the best stuff at the best price (Eddy, Trick Flow, Comp, AFR, etc)
Cost is a factor but not if it means cutting corners.
Thanks for your ideas!
Bob
Bob
