I am trying to install a 1967 fold down seat panel into the backseat of my convertible.
I have read on this site that the convertible seat is the correct size for the large flat panel that is secured down to the back side of the backseat.
I also have the correct 67 hinges that bolt down on both sides of the flat panel.
One side of this “flat panel” is very flat & smooth except for the contour around the perimeter. I’m sure this is the side that faces up with the carpet when the whole thing is installed & functioning.
The other side is not so flat & has large horizontal “ribs” molded into its structure (I guess for added strength).
When I try to lay down the ribbed side (facing into the springs & stuffing of the backseat, it will not lay down flat. So I can’t add the fasteners to hold it in place.
My question is: Should I have to remove same of the existing metal bars that are on the inside of the backseat in order to make the “fold down panel” lay down flat?
It looks to me like some of these horizontal & vertical bars would HAVE TO be removed in order to lay the fold down seat panel flat. Then the panel would make the seat structurally sound without the original crisscrossing bars.
Anyone have any experience doing this installation before? Thanks.
