1969 camaro and my front swaybar contacts the frame on both sides as it wraps around to bolt to end links.
The sway bar is 7/8 " , I recently purchased new moog end links with bushings.
The old endlinks installed by the previous owner were shorter and pulled the swaybar down away from the frame. I was told that the correct link is longer than the previous owners install. So I purchased the moog.
Theres a flat spot on the frame that the swaybar runs parallel with before attaching to the end link, its at that point the swaybar makes contact with the frame on both sides. Since I am not the original owner of the car, I don't know if this is even the correct swaybar.
Has anyone else noticed this, anyone got any pictures ????
