1 - 4 of 4 Posts
Rattlehead
Discussion starter · #1 · (Edited)
Hey Guys, got my car back together and got to do some shakedown cruises last weekend (finally!!)
I'm having one issue though. My passenger side brake lights work fine all the time, my drivers side brake lights come and go. I know they run through the turn signal switch so I disconnected/bypassed the switch and both sides work fine. There are two black wires in the connector for the turn signal switch, are they both grounds? I can't see where they go without some dash disassembly so thought I'd ask here before disassembly and/or replacing the switch.
I know bad grounds are almost always the culprit but 40+ year old switches go bad too.
Thanks!!
BTW, car is a '69
Only one black wire: (from Painless site)
GM Designation Painless Painless Turn Signal
Color Wire No. Color Connector
Blk Horn 953 Blk G
Lt.Blu LF Turn Signal 926 Lt.Blu H
Dk.Blu RF Turn Signal 925 Dk.Blu J
Brn Hazard Flasher 951 Brn K
Pur Turn Flasher 952 Pur L
Yellow LR Turn Signal 949 Yellow M
Grn RR Turn Signal 948 Grn N
Wht Stop Lamp Switch 918 Wht P
However, one black wire for horn switch, the other black wire for Key Minder.
1 - 4 of 4 Posts
