Hey guy's,
So I have a 67 Rs with the original 327, and have no power flowing out of my alternator. Here's the fun part, I 1st went to have my alternator tested, which turned out to be good, so I then swaped my voltage regulator with a 68 chevelle, same problem of only 12.5v's coming off of the alternator. So i then thought the place that I had test it had a bad tester, So I went out and bought a "New" (re-built unit) and installed it only to find the same symptoms are present. I checked all my fuses, all good there, I have ran down all my wiring, no present detachments or exposed wires. This is an "all of a sudden" on set problem. Fired her up the day prior with all systems working and normal only to find the next day 12.5v's coming off the alternator with no (at least with my experience) reason as to why. Thanks in advance, and Any and All advice is appreciated
